rear brake lights got a ticket
#21
Yeah those lenses are very legal and look like they are in great shape for the age.
I'd look at bulb output (voltage or correct bulb being used). A loose ground can dim a light like you are seeing. Check the back of the socket to make sure the wires are connected tightly.
#22
The guys are right,
If you have no tint,
And you have already cleaned/polished the lenses,
Then the only thing left is light bulb output.
You most likely have a wiring issue and the bulbs are not getting full voltage. This can be a bad ground wire/connection or hot wire connection.
Did your year Mustang have a relay to supply full voltage to the rear lights? If so, the relay may be bad.
If you don't have a light relay, the switch may be bad. This would be in top of the steering column. It gives you one more thing to test/eliminate. I have seen these go bad before when there wasn't a relay used, because the switch has to run the full amperage of all the lights.
Look up a wiring diagram for your Mustang, this will quickly show if you have relays in your lighting circuits.
bond007
08-26-2015 11:36 PM
