door hinge pin question
Old Sep 12, 2012 | 05:32 PM
StalkerGT's Avatar
StalkerGT
Default door hinge pin question
I just took off my hood and fenders to be sent off for paint...figured it would be a good time to do my door pins and bushings since my doors are sagging a little. What is the the best way way to change them? should i just take the door mounts right off the body since i can get at them? Just curious what the easiest way would be. I have replaced the upper passenger side previously and what a pain that was! A dremel does cut the pins pretty easy though! And also where is a good place to get the door hinge rollers? Autozone wants 30$ just for one side!
Old Sep 13, 2012 | 03:22 PM
Five0hFox's Avatar
Five0hFox
I did my pins one at a time. Cut them with a dremel, popped them out and put the new ones in. I had a stand supporting the door and another person there ready just in case. It was a bit of a pain, but I think that would be easier than removing the door and getting it back on and lined up.
Old Sep 14, 2012 | 07:22 AM
StalkerGT's Avatar
StalkerGT
Didn't think about having to line the door up! Thanks for the info!
Old Sep 14, 2012 | 04:25 PM
DRAGUL's Avatar
DRAGUL
Did it once taking off the hinge and it was a pain getting the door re-aligned. Might be easier though since you have the fender off, and have direct access to the bolts.
But then again you will not be able to re-align with the fender
Old Sep 15, 2012 | 05:38 AM
eb2gt's Avatar
eb2gt
NAPA sells what you want in hinge pin kits and rollers.
Old Sep 15, 2012 | 09:52 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
check rockauto.com for parts they probably have the stuff for a decent price
Old Sep 15, 2012 | 11:23 AM
StalkerGT's Avatar
StalkerGT
Thanks for all the info! I found a hinge pin kit with the rollers for 30 with free shipping through late model restoration
Nov 18, 2015 01:34 PM
Sep 10, 2015 07:23 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
