Well it's stronger than a stock T5, nearly as compatable if you're thinking of dropping one into your Fox. You would need a tremec bellhousing (because bolt pattern is different) and an AOD cross member. You can use the stock T5 crossmember but may have to grind a few spots down. The AOD crossmember on the other hand will let it slide in like butter.
yea because i bought my car with t 3550 in it, im just wondering if its a good aftermarket tranny or what power it will hold. compared to others like the tko's
