Injector sizing
you don't have 400 hp with that set up, which are why 19's work for you, try 19's on a real 400 hp combo and show the duty cycle with an a/f slip as proof on the dyno to support the claim.
Actually you don't have any idea how much hp I have because you don't know anything about my block or what supporting mods I have. I know for a fact as well as two dyno places to back up my claims that 19# injectors work fine up to 400hp, and I've seen them work past if you upgrade the fuel pump with an adj. fuel press reg. Next time you want to say something, you may want to find out your facts first.
19# injectors as a (rule of thumb) on a N/A car @ 85% duty cycle are good for right around 260hp . To reach 400 hp you would need to have 30# injectors and run them at right around 85% duty cycle.
85% duty cycle is about the most you want to push your injectors or they start to float half open and lean out the a/f if you start going close to the 100% mark.
Even if you did tune the adaptive learning of the ecm a/f mix out or keep it in open loop running your injectors at 100% duty is not worth the damage you could cause .
And without a power adder and a healthy one at that you ARENT close to 400hp not even at that crank....
You could get enough fuel from about 50lbs of fuel pressure with 19`s but it wouldnt idle worth a **** without a tune and the injectors still wouldnt last long at that rate!
2) why did you take your 24 lbers out and replace them with 19's ?
3) your dyno guys are retarded and i wouldnt go there anymore for ANYTHING
OP with that set up I personally would go with a fuel pressure regulator and turn it up to 40-42psi. If you would feel more comfortable with a bigger injector then just go 24#. With both set ups in my sig I was running 19# injectors with a regulator. With my bolt on set up I had the fuel pressure set at 40psi with the a/f ratio right at 12.5 and the heads and intake set up I had the pressure set at 43-44psi with the a/f ratio right at 12.7-12.8.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
