e85
Old Apr 13, 2013 | 09:48 PM
Duncan_GT's Avatar
Duncan_GT
So bottom line, should I stick to 93 or upgrade the system to e85?
Old Apr 13, 2013 | 10:03 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Originally Posted by Duncan_GT
So I shouldn't switch? That link you posted had a ton of info. Also looked at e85mustang or something like that. I've read it doesn't build carbon like gasoline does. If I were to switch, is it a matter of just upping the fuel pressure and retuning the fuel curve?
I've never run e85, what you can do is run your current set up on gas, dyno it and see where the duty cycle comes in at and add 30 percent more from that and see if you have enough room for error
Old Apr 13, 2013 | 11:09 PM
Duncan_GT's Avatar
Duncan_GT
Yeah that sounds like a plan. Hopefully the stock transmission doesnt blow up on the dyno
Old Apr 13, 2013 | 11:55 PM
Maxwelhse's Avatar
Maxwelhse
VERY unlikely... The dyno doesn't hit the transmission very hard like a drag launch.
ctgreddy
Sep 20, 2015 08:35 PM
Justin00Stang
Nov 17, 2008 09:22 PM
ThumperMX113
Jul 21, 2008 05:08 PM
Justin00Stang
VMP Tuning
Jul 10, 2008 11:43 AM
KBunny
Sep 25, 2005 08:11 AM
