What kind of Brake Pads I should buy?
Old 06-06-2014, 09:16 AM
zx128
zx128's Avatar
Default What kind of Brake Pads I should buy?
Hi all,
I just wanted to know the OE requirements for my mustang, it's 1994 GT 5.0 with stock rotors. What kind of material (stock) is used? Organic, Semi-metalic or Ceramic? Is it ok if I go with ceramics?
thanks
zx128 is offline
Old 06-06-2014, 11:43 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome to the forum
I think semi-metallic is stock, and what I would use on a daily driver. Just try to get the best pads you can afford. I tried the cheapo sets and they filled my rims with dust in a a couple days.
I've never tried the ceramics, but some love them, some say waste if money.
88 orangepeel notch is offline
Old 06-06-2014, 09:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ceramic is the best way to go for less dusting and less chance of squeal issues
mjr46 is offline
Old 06-07-2014, 08:34 AM
steel pony
steel pony's Avatar
AKEBONO
very good pads and very low dusting...a little more expensive but worth it
steel pony is offline
Old 06-07-2014, 08:50 AM
bluebeastsrt
bluebeastsrt's Avatar
I use hawk performance pads. They will stop you a little sooner than a standard brake pad. If it's a daily driver and your concerned about dust. Ceramic is the way to go.
bluebeastsrt is offline
Old 06-07-2014, 12:23 PM
zx128
zx128's Avatar
Thanks guys for your replies.
I've received email from rockauto.com where I want to buy it, they told me that it's ok to take ceramics, because their term "OE pad material is ceramic" means that the car was originally equipped with ceramics when it was built. However, I have seen in many blogs that the ceramic brake pads are more aggressive to rotors. Maybe it depends to the rotor itself?
zx128 is offline
Old 06-07-2014, 12:31 PM
zx128
zx128's Avatar
Forgot to say, right now I have Raybestos pads which are just great, quite and with good stopping performance but I can't determine what material it is. I think, if I go with ceramics, I'll take raybestos.
zx128 is offline
Old 06-07-2014, 03:34 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Ceramic is the best by far. Organic will dust like crazy and doesnt last. Semi-metallic will squeal when cold. As far as being hard on rotors I call BS on that crap. Some say run softer pads to save your rotors but youll replace pads more often. Id rather run a better pad and replace rotors every few hundred-thousand miles. As long as you dont warp the rotors and need them turned you can just pad slap them and get a **** load of life out of them.
Boss_Hotrod is offline
Old 08-28-2014, 01:03 PM
prbxfd7
prbxfd7's Avatar
Ceramic is the way to go. I used semi-metallic for a while but after switching to ceramic i won't ever go back. Also super quiet.
prbxfd7 is offline
mtgldr
02-03-2024 09:00 PM
2007CalSpec
12-13-2020 11:42 AM
DoctorScary
09-09-2015 07:53 AM
09-08-2015 11:50 AM
Quick Reply: What kind of Brake Pads I should buy?
