need help with more horsepower
Old 04-06-2015, 06:53 AM
kevinp
kevinp's Avatar
not real sure if I want the gt40 heads.I am trying to figure which way I can go with my motor.I don't want to go cheap but my budget is very limited and the wife is another reason.I want to do it right and I don't have a clue where to start.My knowledge is limited to what to get.
kevinp is offline
Old 04-06-2015, 06:58 AM
kevinp
kevinp's Avatar
I also have a 87 what is tfs.My brother in-law is gonna help me and said I could not bore,get a cam and work my heads and that would give me a bit more horses.I was woundering if I would by able to tell a difference.
kevinp is offline
Old 04-06-2015, 10:14 AM
88 orangepeel notch
88 orangepeel notch's Avatar
What mods are on the car currently ? Or is this a complete stocker yet ?
What are your plans for this car ? A fun daily driver, strip car, road course, etc.
88 orangepeel notch is offline
Old 04-11-2015, 10:12 AM
kevinp
kevinp's Avatar
motor is stock and I want a fun daily driver.I have 3.55 and a t-5 already in the 89.When I bought it the car had no motor so I found a motor and did a compression test on it and the number one cylinder only had 90 psi compared to about 120 on the others.The guy I got it from said it hadn't been started for a while and I never heard it run.
kevinp is offline
Old 04-13-2015, 07:38 AM
88 orangepeel notch
Soooo........ your looking for more power for the 89, while finding the cause of the low compression?
I can only suggest camping out on Craigslist or a forums "used parts" section and grab everything used. Research the mods your interested in then dive in. You'll save a ton of cash if you can do the wrenching yourself.
Old 04-15-2015, 08:55 PM
65Raven65
65Raven65's Avatar
TFS = Trick Flow
They make heads and intakes, and I think cams too.
65Raven65 is offline
Old 04-19-2015, 12:11 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
time to rebuild that motor, not mod it.......add some oil in the suspect cylinder and if compression jumps significantly = ring issue and if not do a leak down test after that to locate the source of the loss of compression........................of course you could follow this advice that I had with an ignorant fool a while back on a 40 year old motor: "From my experience, a lot of times on older engines the cylinder bores and pistons are in good shape - - - the rings are worn." Grant it your motor is not 40 years old but most 5.0's have been ridden hard and put away wet so once you find the source of low compression, you most likely will be rebuilding it and not just reringing like the unlearned individual I had a conversation with tried to promote to an OP.
mjr46 is offline
01-06-2016 07:03 PM
GimpyHSHS
09-18-2015 12:27 PM
09-18-2015 12:25 PM
Other Professional Racing
09-10-2015 11:41 AM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: need help with more horsepower
