High Performance Distrubtor
I have a 1991 mustang 5.0 and everything's stock. I was thinking about getting a high performance distrubtor and wanted to know will it really help increase performance and If so I don' know which one to get....thanks.
mdj89, on a "stock" engine I don't think you will be able to notice a "power increase", but there will be a "efficiency increase" that could be noticed ie. Little better fuel mileage, engine runs smoother, etc. As far as the "high performance" distributor goes, I have always relied on MSD products, with no complaints.
Unfortunately, MSD isnt putting out the quality parts theyve always been known for.Their distributors are hit & mis.Their housing,shaft,sealed bearing and gears are top notch, but their pip sensors & tfi modules are cheap and have been known to go out in a few months time.Does every distributor do this that goes out their door,No,but alot due.If you could combine the MSD hard parts with a Ford Motorcraft pip & tfi module,you'd have a nice distributor.If your stock distributor doesnt have alot of play in it,indicating the bushing and/or shaft arent worn excessively, I feel youre better off replacing the pip & tfi module in your distributor and running it.Unfortunately, the pip is normally the main part that goes out and most prefer buying another distributor rather than replacing the pip.
Jazzer The Cat
Dec 17, 2006 04:21 AM
