Vacuum line victim....plus help!
A vacuum line came undone in my 95 GT 5.0 SN95. In the attached picture it's the cylinder shaped piece with the white T connected vacuum lines on the top and bundled wires coming out bottom, in middle of pic. Located on engine area on passenger fire wall. The hose going to right side of picture is the one that came off of somewhere in the engine but I don't know where. If anyone knows what the cylinder shaped part with the T connector on top is OR where the hose goes I'd really appreciate any help here, the car is running really rough.
The cylinder with white T connecror on top n wires from bottom, where does the vacuum hose going to right side of picture go to?
I can see the port for the hose when I put my cell in selfie mode & look in there but I cant get to the port.
Don't let them sell you a canister. If yer clever, you can determine if the solenoid is any good or not, by removing it, blowing air through it with and without 12Volts supplied to the two wires. Only thing the PCM can monitor is Solenoid current flow (or lack of it), and if the solenoid is good, no codes are stored. I blocked the flow through my '94 solenoid. Long story, but she runs real nice! imp
I needed the hose on the other side replaced too so I took it to Pep Boys. I supplied the hoses & took off the sway bar over the engine already & its still costing $204.
I need to stop being so lazy.
Thanks for your help
The several vacuum ports on Mustang 5.0s seem to be "spread" out to relieve the amount of flow from just one location, IOW, in different runners. The canister purge sol. is so close to the manifold, the short drag of air to operate it would likely not matter either way, unless it's diaphragm were ruptured, and it leaked constantly when turned "ON'. imp
robpawn
May 16, 2025 11:15 AM
