Over heating problem
Old Dec 3, 2018 | 07:16 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
you may get around $1500 for a v1 s-trim, which would pay for your shortblock
i did have to re-tune mine when i took my v3 off, but it did run without a re-tune. It was just ran a bit rich.
edit: by the way, that is really nice car.
Old Dec 3, 2018 | 08:28 AM
drhoward's Avatar
drhoward
Penis Mod Erator
I blew up my old engine a few years ago, you can typically find 302's in decent shape for cheap if you look around and the swap isn't that bad to do. I found a rebuilt bottom end, assembled for mine for 700 dollars and it's been in my car for almost 10 years now.
Old Dec 3, 2018 | 11:05 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
yeah i would go ^ route or find an exploder/mountaineer engine. Swap the parts like the oil pump, pan, etc... off of the current engine and then turn around and make money on the extra set of heads and intake. Those heads of yours may be cracked anyways.
Old Dec 4, 2018 | 09:12 AM
LX 5.0's Avatar
LX 5.0
Thanks for all the advice. Yesterday I learned at the shop it appeared the motor was bored out without enlarging the pistons. Motor is going to a machine shop today so I will know more details later. Do you guys advice staying away from a 347? If I go big I was thinking of saving up for a ATK 331 short block which are refurbished. I've also been looking at Tristar motors, and wholesale-engines.com.
Old Dec 4, 2018 | 09:35 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
i don't know about any of those places. Personally, I bought a used engine and put bearings and rings in it. I still have around 135 compression on each cylinder after being supercharged for around 7 years and 80k+ miles. Engine still doesn't use oil between changes.
The thing about going up in displacement, is the parts you really need to buy along with it. Heads, cam, intake, etc... and i don't know why you would stay away from a 347, unless you are going to boost it. In that case, I probably wouldn't go up in displacement anyways. the low end grunt gained from the stroker displacement will likely be traded off for less reliability out of the stock block on the top end in my opinion.
If you go aftermarket block and boost it, by all means, the bigger the better
Old Dec 10, 2018 | 09:10 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
347 is fine in a stock block just don't boost the heck out of it, and stay away from ATK they are junk reman POS.........any issue I've ever had at my shop has been with an ATK REMAN.
LX 5.0
Nov 20, 2018 05:05 PM
Burtonsnow157
Apr 9, 2014 10:00 AM
92Mustang92
Sep 30, 2009 05:15 PM
abrush
Aug 20, 2009 11:53 AM
EmperorOfChicken
Oct 20, 2006 01:55 AM
