Transmission issues?
Old May 19, 2021 | 03:37 PM
mcole024@icloud.com's Avatar
mcole024@icloud.com
Default Transmission issues?
I’m new to the mustang world. I bought a 1995 gt with a 1999 5.0L swap to build with my son. I’m having an issue. When I let off the gas I’m getting a clicking noise I believe from the tranny. It’s a w/c T5 standard. It’s not hard to shift doesn’t come out of gear. Shifts just fine. If I give it gas the noise isn’t there. Only when I let off the throttle is when I hear it start to click. U-joints are good. Does anyone know what this could be before I tear it out? An if I have to replace the transmission will a standard out of a v-6 work? I know the gear ratio would be different so could I just switch the gears? Any help would be greatly appreciated.
Old May 19, 2021 | 03:42 PM
mcole024@icloud.com
Sorry it’s a 1991 5.0L
Old May 19, 2021 | 04:03 PM
mcole024@icloud.com
The transmission also has a winding noise constantly
Old May 19, 2021 | 04:43 PM
drhoward's Avatar
drhoward
Penis Mod Erator
You sure it's your transmission and not your rear end?
A t5 from a fox will work, you just need to make sure it has the correct input shaft. Some of the v6's work as well but I'm not sure of the compatible years.
Old May 19, 2021 | 05:07 PM
drhoward's Avatar
drhoward
Penis Mod Erator
They have a pretty good breakdown of the differences between the t5's here:
https://www.moderndriveline.com/the-...ces-of-the-t5/
Old May 19, 2021 | 09:16 PM
mcole024@icloud.com
It sounds like it’s right under me. Almost like a howl, when I’m giving it gas. But as soon as I let off it clicks. An thanks for the article it was definitely helpful.
Old May 19, 2021 | 09:22 PM
mcole024@icloud.com
An if I take it out of gear an let it coast it don’t make any noises at all. Only when in gear.
GT_Yea
Dec 20, 2013 05:42 AM
Jmrz1919
Dec 16, 2009 02:49 PM
Ford Drag Team
Feb 10, 2009 05:20 AM
NotStok
Mar 26, 2008 11:06 AM
ckyguy68
Jun 4, 2006 05:05 AM
