is the stock 15 gt x or h pipe?
It's just like CharlieW said: a central single piece resonator with 2 tubes in and 2 tubes out.
It is a welded integral piece with the axleback so that to change the mufflers, you also have to pull off the resonator because the entire axleback and the resonator are welded together as a single piece.
http://www.mustang6g.com/wp-content/...ns-700x510.jpg
Also, I doubt it's like a pro-chamber.
It's essentially one large piece, so for an axleback you would be required to cut the pipe rear of the axle and attach the new parts. Active exhaust will cut just in front of the axle but both will be post resonator.
