5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Got H-Pipe? WE DO!
Old 11-23-2010, 01:25 PM
Boostaddict
Former Sponsor
Boostaddict's Avatar
Default Got H-Pipe? WE DO!
Introducing the Lethal Performance 3" Offroad H-Pipe. Exclusively made for Lethal Performance!!
NOW SHIPPING $299.00
Lethal Performance 2011 5.0L Mustang GT 3 Offroad H-pipe [LP-2011GTORH] : Lethal Performance, Performance parts for Ford Mustangs
NOTE: We highly recommend running this pipe with a custom tune. If you run this pipe without one not only will the car throw a check engine light but you won't fully benefit from getting rid of the cats. So not only does the tune turn off the rear o2's to prevent the check engine light from coming on it will also turn off the Cat Over Temp protection feature in the tune. That feature dumps fuel in order to cool the stock cats. Since the cat are no longer used with this pipe that feature if not turned off will only richen up the air fuel mixture and result in sacrificing some performance.
Lethal Performance is proud to release our exclusive 3" offroad H-pipe for the 2011 5.0L Mustang GT. Just like our offroad x-pipe for the 2011 5.0L Mustang GT you can expect excellent gains and a more aggressive sounding exhaust. Our offroad Hpipe is made with 3" mandrel bent aluminized steel and is a direct bolt-on requiring no cutting or welding. Installation should take you less than 1 hour using simple hand tools. Just remove the stock catted h-pipe and install our 3" offroad pipe and you can expect gains of up to 14rwhp.
Features:
3" Mandrel Bent Tubing
Aluminized Steel Construction
Direct Bolt-On (Requires no cutting or welding)
Increased Sound and Performance
Up to 14rwhp Gain Over the Stock Catted Mid-Pipe
Includes All Necessary Hardware for Installation
Installs in Less than 1 Hour
**Offroad Use Only**
Boostaddict is offline
Old 11-23-2010, 10:20 PM
zilla8
zilla8's Avatar
Looks like a nice set up,
a lot of people have been asking for a H-pipe for the new 5.0
I have highflow cats here in California but I might get a offroad pipe for the track at some point.
Do you know if rear o2's are turned off in my tune that the COT is also disabled?
I want to make sure that I'm not having fuel dumped to cool the cats even though the rear o2's are turned off in my tune.
thanks for your help
zilla8 is offline
Old 11-24-2010, 09:16 AM
amplifier28
amplifier28's Avatar
i want an h-pipe that installs after the cats that includes the pipes that run back to the stock axle-back.
amplifier28 is offline
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
Scottyboy187
11-05-2015 04:18 PM
09-24-2015 09:18 PM
GimpyHSHS
08-29-2015 06:30 PM
whatsup62
08-29-2015 01:25 PM
Quick Reply: Got H-Pipe? WE DO!
