Major issue with skip shift causing violent down shifts!
i was just driving along coming up on a turn i go to downshift and i'm pushed into second (it wouldn't go into 4th) its happens more than once, i suspect skip shift is causing this issue. it scares the **** out of me when it happens and i have noticed some weird shifting issues occasional grind in 5th etc. is this happening to anyone else?
Skip shift should only be functioning on 1-2 up shifts with the engine rpm at 1500-1900 rpm. If you have rough down shifts, you should visit the dealer.
The gates are close together also so it takes an easy hand to hit the gate.
I disconnected the skip shift solenoid on the top, rear passenger corner of the transmission with no ill results. Several have done this with no negative results.
From the sounds of your problem you are describing, you should have probably waited a little longer before downshifting to second (your tranny output shaft was still turning too fast) or you should have downshifted into third instead..
The only reason why I say this is because I am guessing you were going to fast for 2nd gear and too slow for 4th and your syncros were locking your out, thus the grinding as you try to throw it into the gear you want to go into.
Now, if your speed was reasonable for forth gear that you were trying to downshift into, the syncros should not have done that.
Your tranny might be screwed up (maybe not your fault), and you should take it in and make a claim under your drivetrain warranty.
zanemoseley
Sep 6, 2015 12:58 PM
