Popping/knocking sound after spring install?
Greetings Everyone,
I just installed some Eibach Pro springs and adjustable panhard bar on my 2012 gt, and have been experiencing a popping/knocking sound that I think is coming from the rear.
Occurs during heavy bumps or when turning over different angled ground planes. It is not bottoming out. It almost sounds like a suspension bit is hitting the underside of the car when the springs compress and I dont think its the bump stop. But this is just a random guess in the dark. I double-checked all my work.
Thanks for you thoughts
I would double check everything. Look for rubbed spots on all parts e.g., missing paint, gouge marks etc.
I've lowered a few cars. I have always gotten "additional" sounds, but knowing it was installed correctly I did not worry about it.
Hopefully more will chime in, but if everything looks good I would not worry too much.
I've always gotten hella loud popping after gears as well. On turns while pushing in clutch
its likely the top of your rear spring rungs clacking as they touch each other during rebound and compression. I had this problem on my 2010 with eibach pro's and sportlines. you will need these to stop the noise:
http://www.phase2motortrend.com/esspnore.html
when i took my sportlines off to replace them with pro's, i saw evidence of contact of the top two rungs clacking together...
