5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
wheel combo?
Old May 9, 2012 | 01:19 PM
ogsucka's Avatar
ogsucka
Default wheel combo?
Does anyone know if we can do a 19" rim up front and a 20" rim in the back? How would it effect the abs system, or would it throw a code/disable it? Has anyone seen or heard of anyone doing this set up?
Thanks
Old May 9, 2012 | 01:56 PM
Enochius's Avatar
Enochius
I don't know about rim size bit I know several people who run different tire sizes front and rear without any issue. I know one guy whose tires in the front are about 1.5 inches shorter in the front than the back and he has no problems.
Old May 9, 2012 | 02:18 PM
Tygr1's Avatar
Tygr1
You can run 20s with 19s fine. If they don't rub, you're good to go.
Old May 9, 2012 | 02:30 PM
chain1's Avatar
chain1
I was wondering the same thing. I'm thinking of buying my friends 2012 GT500 SVT rims and they are 19/20 so it shouldn't be an issue.
Old May 10, 2012 | 02:49 PM
12GTPDX's Avatar
12GTPDX
Totally doable, and since there's currently only a couple of street 295/35/19 tires being made (which would give you a stock 27" wheel/tire height), I know some folks who run the 20s out back just so they have more choices of tires AND can match OEM tire height.
Otherwise, for accurate speedo/odo readings, you'd need to reset the tire size in your tune if you end up with a different height.
Old May 10, 2012 | 06:23 PM
MrSandman's Avatar
MrSandman
That's how the GT500s are set up.
jwog666
Dec 27, 2021 08:09 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
