5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Engine removal
Old May 11, 2012 | 08:59 PM
txcharlie's Avatar
txcharlie
Default Engine removal
Has anyone removed the engine from their 2011+ GT? I know the Ford SM procedure is to pull it from the top, but I seem to remember someone dropping the K member and front suspension as a unit and lifting the body off.
Old May 13, 2012 | 05:59 PM
clowe1965's Avatar
clowe1965
Check out the online manual on allfordmustangs in the technical section. Lifting it from the top is easier and safer, you're not messing with a 3000 lb car and having to support the engine at the same time. Not to say its not possible, just not as easy.
The only mention of dropping the k-member I can recall was a header swap, which the engine was lowered to get clearance but it was not removed.
Granatelli Sales
Jan 20, 2020 12:34 AM
MusicCity615
Sep 27, 2015 12:53 AM
spamedic
Sep 9, 2015 12:15 AM
Gary Ugarek
Sep 5, 2015 09:03 PM
