5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Engine shuts off while driving
Old May 19, 2012 | 10:22 AM
zagurto's Avatar
zagurto
Default Engine shuts off while driving
My 89 -5.0 shuts off after driving for 1 hour, it will crank but will not start, if I wait 30 minutes, it will start and run for another hour. Already replaced the module next to the distributor and didn't fix it. Any other ideas?
Old May 20, 2012 | 06:45 AM
scottmach's Avatar
scottmach
Here's an idea, post in the correct forum.
Old May 20, 2012 | 06:51 PM
kegboss1's Avatar
kegboss1
Wink
This forum is for the real 5.0 !!!
Old May 20, 2012 | 09:11 PM
Cobrakev's Avatar
Cobrakev
To answer your question, there is a module on the distributor( the one with the plug on it), that when it heat's up, it cut's out the spark. This is caused by heat build-up. Change out this module, and use the right heat grease when you install it.
Old May 21, 2012 | 05:37 PM
scottmach's Avatar
scottmach
jpplaw
Mar 19, 2025 08:53 AM
Design1795
Jan 24, 2017 10:38 PM
Design1795
Aug 24, 2015 04:41 PM
drumhedd2005
Aug 13, 2015 09:59 AM
HIS S-197
Aug 10, 2015 05:47 PM
