Water leaking into CAI of 2013 GT????
Once i pick mine up, most likely seems like this is the most viable solution. I asked Steeda via livechat and they have no reports of any issues yet. Once i get mine i will be able to get further troubleshooting done.
Btw I put a paper towel on top of the factory air box, closed the hood, washed my car in a "normal" fashion, and when I checked under the hood the paper towel was soaked! This is not looking good.
I know we install the CAI for performance. Aslo looks. But, we really don't get that much out of it unless installing FI which then the CAI would be necessary.
I have an auto which I think only has 3:15 gears. If I want more go power then a better option would be to just do a tune, change gears to 3:55 or 3:73 and install mufflers for sound. Which I am installing Borla in a week.
I do not go to track. The car stock has lots of go and looks good as is.
Maybe all that have 2013 gt's just don't buy a CAI and then maybe when sells are zero the mfg's will do something. My thoughts would be to just add/bolt on something to the cover on the hood which would cause water to drain somewher other then on the filter.
Put scoops over the heat riser vents .......lol....
Anyone ever think Ford did this placement for a reason.......
Also, with the vent above the CAI filter, wouldn't that subject it to pulling in more hot air vs cold air since the hot air is trying to escape there?
I always thought heat riser vents worked better further back on the hood.....even the Shelby's are near the front. Seems like they remove radiator heat....not engine heat when the car is moving.
Those vents are not really pulling in heat. There is nothing under the hood to cause a suction. Think about it. When the car is moving, air enters through the front. As air enters the engine compartment, the vents allow more heat to escape easier through the vents. Air raises and is light. Water is heavy and gravity will pull it down through the vent and unfortunately onto the CAI.
I still love my GT/CS and would still have gotten it even knowing this dilema.
Not installing a CAI is not a big deal. Someone will come up with something for those who want to install the CAI.
I use to ride a Harley with a CAI. It was expose to rain and I rode in the rain. All I did was put the cover provided over the filter and no water entered.
The solution for us is probably just around the corner and a simple one.
Attention American Muscle: Help solve this....
Hey boss, i have a special request. I have to different networks to access the internet at my current location but neither will display pictures on forums (ughh). Can you email me you pic to my gmail found on my accounts page? Really curious to see what you did. Thanks!
if it isn't displaying pics on forums your companies network policy is blocking photobucket... lame, but a lot of companies are doing that now.
as far as water entering the CAI a mechanic told me as long as the engine is running you can hook a water hose up to your intake and the engine will keep running without a problem. I'm not sure how much I trust that, I wouldn't try it. But this might not be as big of an issue as you guys are thinking it is. That might also be why no problems have been reported from using it without modification
