5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Intake Air Temperature Sensor
Old Jul 1, 2012 | 10:30 PM
2011P51GT's Avatar
2011P51GT
Default Intake Air Temperature Sensor
My 2011 Mustang GT just threw a P0111 error code (Intake Air Temperature out of range). Here is the thing - it was like 110 degrees outside. Could that cause it, or do you think I really have an issue with the thermistor?
Any ideas?
Old Jul 3, 2012 | 03:19 PM
JD_GTCS's Avatar
JD_GTCS
Sorry, too new to the 2013 to know if the ambient temp would affect the intake temp and cause a fault so far. Just responding to bump you up and to find out how this may affect my pony.
Old Jul 3, 2012 | 03:25 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Do you have a scanner with data logging capabilities? It will give you the actual inlet temp. Also, is your intake sucking air from the engine compartment or is it pulling it from the fender or under the front lip of the hood?
Engine compartment is my guess. High ambient conditions + traffic will cause a high intake temp. What it takes to throw that code, I have no idea.
Old Jul 5, 2012 | 02:34 PM
Mishri's Avatar
Mishri
Mish-ogynist
supercharger + high ambient temp might be a problem, I'd monitor IAT's, high enough temps can cause detonation, leading to problems, even engine failure. datalog it while doing your normal driving. or get a good gauge that can show you different parameters and keep an eye on it.
Old Jul 7, 2012 | 06:06 PM
moosestang's Avatar
moosestang
Where's the IAT sensor on the 5.0? Is it still with the MAF sensor?
Jb145700
Aug 21, 2022 06:37 AM
04stangman
Sep 17, 2015 01:45 PM
TfcCDR
Sep 14, 2015 12:08 PM
kevsgt
Sep 9, 2015 06:20 AM
Sep 8, 2015 11:50 AM
