5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
aluminator
Old Nov 18, 2012 | 04:28 AM
kennebell's Avatar
kennebell
Default aluminator
hey guys any one know what hp rate for the ford racing aluminator engine
Old Nov 18, 2012 | 11:07 AM
SpartaPerformance's Avatar
SpartaPerformance
700-800 HP easily for the assembled units, blocks can handle 1,200
Old Nov 19, 2012 | 05:00 AM
Scott2's Avatar
Scott2
To support that power range should the FRPP main bolts and main side bolts be replaced with ARP studs and bolts?
Old Nov 19, 2012 | 04:30 PM
SpartaPerformance
No not required, the FRPP blocks are a lot more stout then a lot of people realize.
Old Nov 25, 2012 | 02:06 PM
JIM5.0's Avatar
JIM5.0
Don't the Aluminator blocks, PN M-6007-A50NA & M-6007-A50SC, already come with ARP bolts as part of the crate engine?
As for the main caps, the Modulars are four bolt mains plus 2 more cross bolted for each cap (6 total bolts per cap). Even without ARP bolts for the mains, the stock 6 bolts will provide tremendous strength keeping those caps in place even under crazy boost.
Old Nov 26, 2012 | 04:57 PM
SpartaPerformance
I just went through the FRPP catalog and neither complete or short block specify, however you are correct the stock caps are plenty strong to over 1,200 HP when everything is spinning smoothly
Tach9
Nov 30, 2007 12:13 PM
88blk5.0
Mar 3, 2007 07:15 PM
0ur04GT
Jan 2, 2006 06:43 PM
NITROSTANGRACING
Mar 25, 2005 01:48 PM
New Era Performance
Jun 18, 2004 04:33 PM
