volt and pressure gauges
They are heavily filtered/averaged so that they won't be jumping up and down. If they weren't people would think their car was behaving erratically and take it to the dealer all the time. Try activating engineering test mode and watch the actual numbers if your interested. Other than that you'll have to get some gauges if you want to monitor it full time.
You have to do it every time you start the car, same thing as sport mode. With the key off, hold down the system and reset buttons. Start the car, still holding the buttons down. The message center will eventually flash "engineering test mode" and then hitting the system button cycles through all the data. Digital speedo, tach, fuel level, bunch of other sensors that i cant remember. To exit you have to cut the engine off.
Its cool, but not very useful other than diagnostics. Most annoying part is if you go past a setting, because there are about 50 of them and you have to scroll all the way back to get to it.
jwog666
12-27-2021 08:09 PM
