What's the difference?
Old Mar 9, 2006 | 06:18 PM
1fastzook's Avatar
1fastzook
Default RE: What's the difference?
yes but i wouldnt go over 500-600 watts per sub.Right know im running 2 amps per sub soon to be 4 per sub
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
www.ikesound.com they sell refurbished equipment for cheap....
Old Mar 9, 2006 | 06:35 PM
stangman2354's Avatar
stangman2354
http://www.ikesound.com/product-product_id/3777
What about this one?
Old Mar 9, 2006 | 06:53 PM
1fastzook's Avatar
1fastzook
that one would probally be perfect for your subs
Old Mar 9, 2006 | 06:59 PM
stangman2354
is MA audio pretty good brand? And do you think it would hit pretty hard.
Old Mar 9, 2006 | 07:01 PM
1fastzook's Avatar
1fastzook
check out the us amps xt-200d for 399.00,hi fonics bx2005d on ikesound or the ma audio either one will be a good choice but i woul get the us amp myself
stangman2354
and do you think I would need a capaciter for that amp or do you think i would be fine? And if so how do you hook up a capaciter do you just run it to the battery then to the amp and what slot does it go into the amp. Thanks for all the help man.
Old Mar 9, 2006 | 07:04 PM
1fastzook's Avatar
1fastzook
either off them amps will sound good they are all good brands it should hit pretty hard but every one has their own defintion what loud is.it should be a good bang for the buck
Old Mar 9, 2006 | 07:14 PM
1fastzook's Avatar
1fastzook
a cap is more like a band aid for a system it will help out some but its always better to get a better battery or a better alt or both.once you drain the power out of the cap your wasting all you juice out of the alt to try to charge up the cap.Instead of buying the cap upgrade to a bigger and better batt but if you already have the cap put it in when you get the amp and see if it helps.A cap is easy to hook . you just take the power wire in the back [the one going to your batt]and hook it up to the pos+ on the cap and you can hook another power wire from the cap to your pos+ on the amp and just ground the cap to body or frame and thats it
Old Mar 9, 2006 | 08:33 PM
bonesninja's Avatar
bonesninja
one of the more noticable differences between a mono amp and a multi-channel amp is that most mono's these days are class d design and most multi-channel amps are a/b design. most audiophiles like myself will use a/b over class d but class d are generally more efficient but sq will suffer. however, GENERALLY SPEAKING, most people will not care or even notice the difference between the 2 when used for subs. on the front stage tho the difference is day and night.
