Mach 460 + HU + Amp + Sub
Old Apr 5, 2006 | 01:11 AM
BigFuzzyArchon's Avatar
BigFuzzyArchon
Default Mach 460 + HU + Amp + Sub
I plan on adding a new HU amp and subwoofer to my Mach 460 sound system. I already know that I need a special connector to allow the mach system to work with a new head unit.
I was planning on just doing HU + that adapter first and then waiting a bit until I get the amp/sub for it.
I heard that the best way to keep the speakers for the mach460 and have them still sound good is to get a HU with a built-in crossover with high and low pass filter.
The Pioneer Premier 860MP HU (here) has this type of crossover built in.
So what it is basically doing is turning off the bass to all my speakers so it allows subwoofer to play the bass only, correct?
Do you think this is the best way to add subs to a mach460 without changing out the entire system? I really do not want to change out the mach speakers. I think they are just fine and would sound great if they didn't play bass and I added a subwoofer.
Plus I really need Aux Input for my mp3 player.
Edit:
I have a Vert if this makes any difference in sound
Old Apr 5, 2006 | 04:32 AM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: Mach 460 + HU + Amp + Sub
You could manually adjust the bass settings with the cd player. If that is what you are asking.
Old Apr 7, 2006 | 12:28 AM
BigFuzzyArchon
yea i want to adjust the bass so that my stock speakers dont play the frequency that my sub plays. this is why I need a crossover built into the headunit.
Im just not sure if I need a 2-way or a 3-way crossover.
Also im confused about the wiring harness to hook up the mach460 to a new headunit. I have researched this and supposidly i need this adapter
http://www.audio-discounters.com/70-5511.html
This will mean that the amps in there now will continue to work and still play all the speakers in there right? I have a 2000 GT Convertible.
I have read the guide on replacing the headunit on a 2001 w/mach 460. Anybody know if a 2000 is the same as the 2001? It says I need both high and low pass crossover on the headunit. What is the difference in the 3-way vs 2-way crossover?
Old Apr 7, 2006 | 11:43 AM
Danbert's Avatar
Danbert
Surprisingly enough there is two sides to the definition of crossover types.
In most all cases both in Pro audio and car audio crossovers are defined as below.
2-way = High pass output and low pass output
3-way = High pass output, band pass output (midrange), and low pass output.
I have actually heard of a 3-way being refered to as a crossover with front, rear, and bass outputs.
Jensen used to refer to this set up as 3-way back in the early 90's.
You want a head unit that has a built in 2-way crossover that makes the front and rear outputs high pass and then has a separate sub out.
Old Apr 7, 2006 | 08:06 PM
BigFuzzyArchon
alright, that means I can get this kenwood HU i liked much more
http://www.crutchfield.com/S-ZzhZxno...113KDCX790#Tab
For sale on eBay for $185
System E's+: In addition to System Q Sound Control, the KDC-X790 features the System E's+ crossover system for the speaker and preamp outputs. You can make the following adjustments:
* Front High Pass Filter: 40Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz, 180 Hz, 220Hz, or Through (no filter)
* Rear High Pass Filter: 40Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz, 180 Hz, 220Hz or Through (no filter)
* Low Pass Filter: 50Hz, 60Hz, 80Hz, 100Hz, 120Hz or Through (no filter)
and anybody know if that harness ( http://www.audio-discounters.com/70-5511.html ) is the one that will make my **** work?
Old Apr 10, 2006 | 10:46 PM
BigFuzzyArchon
bump
i really need to know if that is the correct harness for adding a new headunit
and also if that is the correct kind of built in crossover
thanks
Old Apr 10, 2006 | 10:55 PM
pj1010's Avatar
pj1010
You should really do some searching before posting. There have bene at least 100 threads dealing with Mach 460 stereos/harnesses.
Old Apr 11, 2006 | 12:14 AM
BigFuzzyArchon
i have searched, nothing with the 2000 Mach460 sound system
The 2001 mach system is different. It is double din. Mine is 2x 1 din so I can only assume the wiring is different, which is why I made my own thread. If the wiring is the same as the 2001 in the 2000 then please correct me, that is all I am looking for.
the changing headunit guide on stangnet is for a 2001 mustang. It also doesn't specify needing a 2-way or 3-way crossover but 2-way crossover is the most popular, so I can only assume that. Purpose of me coming here is to talk about the experiences of other's in their quest for a new HU on the mach460 system and make sure I do everything correct the first time around. I would prefer not to **** anything up.
The closest post I found to one of my questions is about the '99 Mach460 system w/ metra harness and new HU and it being too loud.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
