Running speaker wire into trunk
Old Apr 8, 2006 | 07:02 PM
chadfrombog's Avatar
chadfrombog
Default Running speaker wire into trunk
Can anyone give me any insight on how you may have run a power cable from battery or RCA cables into trunk on a 95 (or so) Convertible?
I dont want to tear up stuff, but I cannot find a way to get the wire around back seat...
Thanks in advance.
Chad
Old Apr 8, 2006 | 08:18 PM
powerkord's Avatar
powerkord
Default RE: Running speaker wire into trunk
pardon my crappy terminoloy.........I ran mine under all the plastic crap, then tucked it next to the seat and behind the seat under the big vinal thingy theres a gap where you can run them into the trunk, thats how I have mine right now, but Im gonna figure something els out soon, cause this is kinda the halfa**ed way to do it.
Old Apr 10, 2006 | 11:32 PM
Brute03's Avatar
Brute03
Thats sort of how i did mine. i just ran it under the trim on the door sill and tucked it in the gap at the end of the seat, out of sight out of mind
Old Apr 11, 2006 | 04:59 PM
Ninety5five0's Avatar
Ninety5five0
I have a 95, there is a big ol' rubber plug in the firewall, some where up above the pedals. Push that out or pull it out, then fish your power wire from the battery through that hole, its plenty big enough. And the plastic right inside the door pops right up, tuck it under there, and then up beside the back seat, from there its a home run to the trunk. just make sure you go under the hinge for the back seat.
Old Apr 12, 2006 | 02:29 PM
Melectrok's Avatar
Melectrok
ORIGINAL: Ninety5five0
This will only work if you have an automatic transmission. And also its better to leave the rubber plug inplace and slit it with a knife. That way there is no metal rubbing the power wire.
Old Apr 12, 2006 | 02:42 PM
Danbert's Avatar
Danbert
I have that same type plug in my '00 5 spd and had no problem running the power cable through it. I slit it and ran it the cable through.
Old Apr 12, 2006 | 07:37 PM
Ninety5five0
No No, my 95 is a 5spd, and so is my friends 95 3.8 5spd, and we both have those lil rubber plugs
wire loom also works to protect the power wire...
Old Apr 16, 2006 | 07:27 PM
Danbert's Avatar
Danbert
You can always do what this guy did. I was sitting in McD's in WA yesterday and looked out teh window at the right time I guess. Look for teh red line at the base of the A pillar. That is his power wire.
[IMG]local://upfiles/28567/623B8ADA83B2479BA4BD885951EAA72B.jpg[/IMG]
Old Apr 17, 2006 | 02:25 PM
Melectrok's Avatar
Melectrok
you have to take the side panel off next to the seat. Unless your really carefule its hard to tuck the powerwire in there without damaging it. If you take it off there is all kinds of room.
carid
Jul 8, 2016 09:55 AM
2007StangV6
Jan 28, 2016 06:09 PM
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
