Can a 5speed car use a remote start
Old May 9, 2006 | 05:41 PM
Blade660's Avatar
Blade660
Default Can a 5speed car use a remote start
I saw the post on remote starters and alarms that was just posted up in this section. I did not want to hijack his post so here is my own with my question. I have a 2001 GT 5speed. Can a remote starter be added to my car? Thanks.
Old May 9, 2006 | 06:35 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: Can a 5speed car use a remote start
Yes, but it's terribleujnsafe. You can slice the clutch wiring and hook it up.
1. It's illegal.
2. If you turn your car on with the emergency brake accidently off, what do you think will happen?
3. If your on a hill with your brake on and turn it on and you happen to roll into another car...good luck explaining that one.
Old May 9, 2006 | 06:45 PM
Danbert's Avatar
Danbert
I never thought of the legality thing. I will look into it in my state.
Old May 9, 2006 | 09:54 PM
typhoon007's Avatar
typhoon007
Might want to check you check your facts first...
Compustar.com has remote starts that work with Manual transmissions. They use a reservation mode to make sure the car is in neutral. While sitting in the car, engine running, pull the emergency brake, and remove your foot from the brake. Open the door, get out, close door. Engine shuts down after 10-30 seconds, and car is now ready to start. Obviously it is impossible for your car to be in gear, engine running, foot off break, so the method is fairly safe.
It is not illegal by the way, although you have to find a reputable dealer that sells compustar alarms. I believe Autopage also sells manual trans remote starts. You will not however find any Directed electronics brand remote start that works with a manual (Viper, clifford, python, etc.)
Old May 9, 2006 | 10:05 PM
laserred38's Avatar
laserred38
ORIGINAL: typhoon007
the legality issue...i'm not sure...but I know a guy who has the Clifford RSX remote start alarm...installed on his RSX Type-S 6Speed....it CAN be done...but like Hisss said it is unsafe if you are forgetful...i read in Car and Driver I think about a guy who had remote start on his Lambo Countach at Pebble Beach...he accidentally started it and forgot it was in gear and the car lurched forward slamming into a priceless Austin Healey...it doesn't make sense to me how the car would move even if it is in gear though...but IDK how the wiring is hooked-up to the clutch and all that...just shop around it can be done
Old May 9, 2006 | 10:40 PM
seight311's Avatar
seight311
It's not illegal to have on a car, it's illegal for a certified business to install it onto a car. I have it on my car, never really use it that much but to get the features I wanted I had to get an alarm that had remote start and when the installer put it in, he asked if I wanted it hooked up too and I said sure why not. I assume your having it installed, find a guy that works at Best Buy or any other place that installs find the guy that drives the ****tiest car and offer him $75 to install the system they'll probably do it. Otherwise im not sure on this but this situation may be the same situation as having too dark of tint installed, maybe you just need to sign a waiver. Check with shops in your area.
Old May 9, 2006 | 11:54 PM
InstallBay420's Avatar
InstallBay420
No i can assure you that it is legal. I am a mobile electronics installer and i do this sort of thing all the time. There are several different ways to do it. there are certain bypasses you can buy so when the car is left in gear it will either A not start or B will no lunge forward. Or if you are a cheap bastard like me and you know what you are doing, you can simply tap the tire and either ground it or put 12 volts to it. (Do not attempt unless you know what you are doing! or unless you are MECP certified. I am not responsible for people being stupid and trying to do something themselves.)
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
'stangdude
Aug 12, 2015 01:27 PM
