Switched Voltage?
Old May 14, 2006 | 04:40 PM
Outatime's Avatar
Outatime
Default Switched Voltage?
Hi all
I recently hooked a couple of items upto the switched voltage wire (yellow I think) on my harness for the shaker but after I took my keys out of the ignition today I checked the voltage and it was still live, I thought it would go straight off.
Is there a delay of the switched voltage for it to go off or should it go to 0v soon as the ignition is off or door open?
Thank you
Stuart
Old May 14, 2006 | 05:55 PM
bonesninja's Avatar
bonesninja
Default RE: Switched Voltage?
ORIGINAL: Outatime
Hi all
Thank you
Stuart
the red is your ignition controlled wire if i remember correctly. i think you hit the constant wire
Old May 15, 2006 | 02:27 PM
Melectrok's Avatar
Melectrok
Red is Switch/Ignintion, Yellow is constant/Battery
Old May 15, 2006 | 04:13 PM
Melectrok's Avatar
Melectrok
Those colors I gave you are for an aftermarket radio. With the stock I believe it is black with red strip (At least it use to be)
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
TfcCDR
Sep 14, 2015 12:08 PM
