fox body H.U. install
Old May 23, 2006 | 01:06 AM
xgodpigeonx's Avatar
xgodpigeonx
Default fox body H.U. install
ok so as i have stated in a previous thread this car is an electrical nightmare...not my forte'...im hooking up an aftermarket head unit to a 92 fox lx. no amp, just basic. the head unit works, and i have sound out of all six speakers. the only problem i am having is the head unit will not turn on with the car. i have to manually turn it on. also the head unit will not keep its settings, ie bass, trebble, volume...etc... my question is where do i hook up the mem/batt wire. if i hook it up to a constant the presets stay, however the radio will continue to play with the car off. hence my next question... i do not have the rem hooked in the car because it was ripped out...as was the power antenna...why is beyond me. where can i hook up the remote wire to have it turn on and off the headunit? thanks in advance...
Old May 23, 2006 | 11:41 AM
jhonijim's Avatar
jhonijim
Default RE: fox body H.U. install
the remote wire does not have to be hooked up to any thing unless you get a power antena or amp.
-hook the Constant (uselly yellow) to a constant battery scorce with a fuse
-hook the switched (uesly red) to the switched ignition power
it would help if i knew exactly what kind of H.U. you had
Old May 23, 2006 | 12:47 PM
ttocs's Avatar
ttocs
you need to find the +12v switched wire as well as the +12v constant. the constant should be the yellow wire, the switched should be red/light green. Test these wires with a voltmeter or test light AFTER checking ALL the fuses.
Is there a shiney box with a bunch of holes in it in the shape of an hexagon in the bottom of the dash, or under the rear deck?
Granatelli Sales
Jan 20, 2020 12:34 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
kawiguy827
Sep 1, 2015 07:09 PM
