removing the radio
Old Jun 7, 2006 | 12:29 AM
lambeth507's Avatar
lambeth507
Default removing the radio
Hey, just bought a 05 Mustang. Need to know how to remove the Shaker 500 radio to access the wiring. Want to install XM radio. Any tips?
Old Jun 7, 2006 | 12:39 AM
seight311's Avatar
seight311
Default RE: removing the radio
Yes get Sirius.
Old Jun 7, 2006 | 01:42 PM
jdback19's Avatar
jdback19
Get sirius!!! But yeah all you have to do is open up the center console were you will see two screws undo them and pull the whole top of the console off if you have a manual you have to unscrew the shift ****. Once oyu do that there are two panels on each side of the radio give them a pull and they will come off exposing 6 screws for the the plate that holds in your ac ***** traction control buttons you have to unplug these and after taking out the screw this panel should pop out exposing the four screws to the shaker take those out and bam there is your wiring.
Old Jun 7, 2006 | 03:36 PM
seight311's Avatar
seight311
Thanks JD I haven't worked on an 05+ thats why I couldn't post a useful response. I have only sat in one once. Test Drive
jwog666
Dec 27, 2021 08:09 PM
kevsgt
Oct 9, 2015 10:12 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
