Sub Box for 2-10" subs
Old Jul 5, 2006 | 06:34 PM
GTnAZ's Avatar
GTnAZ
Default Sub Box for 2-10" subs
I am looking to make a box that will fit under the rear deck in a 02 GT and that will fit 2-10" subs...
I was wondering if anyone has pics of something they have so i can get some ideals or if someone knows of a website where i can do some research. I have searched on here and didnt come up with much.
TIA for any help!!
Old Jul 12, 2006 | 06:45 PM
01BlueCobraVert's Avatar
01BlueCobraVert
Default RE: Sub Box for 2-10" subs
When building your own box you need to calculate cu. ft. and sub mass. Also do you want the subs so you can see them when you drop your seats? If so you are building what looks like a right angle triangle(forget the term for that triangle). measure from floor to underside of rear deck adding clearance for speakers. Then determine the angle of your back seat. determine depth needed for the subs then use your geometry skills (or look on internet for equations) and you are good to go. Doing the math is he hardest part if you can understand the geometry part the rest is easy. Good Luck
Old Jul 13, 2006 | 06:59 PM
d3mon's Avatar
d3mon
mustang sub enclosure
i know this is for a vert but you get the idea, i have it in my vert (small trunk) with 2 12", and is awesome
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 2, 2015 04:12 PM
