radio cuts out
Old Jul 28, 2006 | 04:15 PM
slick66stang's Avatar
slick66stang
Default radio cuts out
i have a jensen cd player in my 66 coupe. had it wired by a pro lately its been cutting out. its grounded to the floor and the power is coming off the solenoid. what can be problem?
Old Jul 28, 2006 | 04:46 PM
Hawk's Avatar
Hawk
Default RE: radio cuts out
It's a jensen...But seriously, if you know the unit is getting good power and has a good ground, could be the unit itself going bad.
Old Jul 28, 2006 | 04:49 PM
slick66stang
its a new unit isnt there a fuse thats in the unit?
Old Jul 28, 2006 | 07:04 PM
ttocs's Avatar
ttocs
fuses do not go on and off. Does it do this when you hit a bump or just on its own? Turn on power to the radio and see if you can recreat the problem by moving radio or the wires on the back of the radio. Then take some time to see if you can isolate which wire is causing the power problem.
Old Jul 28, 2006 | 07:11 PM
slick66stang
it does it on its own. i tried moving the radio and wires to fix the problem but it still does it. im thinking theres not a good power supply because its wired to my solenoid. could i wire it staright to my battery?
Old Jul 28, 2006 | 09:42 PM
Hawk's Avatar
Hawk
You can wire straight to your battery but as long as the wiring is correct, going to the solenoid shouldn't matter. I usually just test for a positive and splice into the wire myself.
Old Jul 28, 2006 | 09:46 PM
ttocs's Avatar
ttocs
there are two power wires. The red +12v switched wire goes to the selenoid and tells the radio when the key is on. The yellow +12V constant supplies the power to the radio when the key is on. It could be a voltage problem but you would need to meter it to find out.
Old Jul 28, 2006 | 10:07 PM
slick66stang
what 2 wires are u talking about ttocs
jwog666
Dec 27, 2021 08:09 PM
kevsgt
Oct 9, 2015 10:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
mdg
Oct 1, 2015 07:04 AM
