Mach 500 Cd-changer problem
Old Jul 31, 2006 | 03:45 PM
Simon G's Avatar
Simon G
Default Mach 500 Cd-changer problem
My stock Mach 500 has started act a bit weird, it wount always accept my cd's. It only say "Bad disc" and spits it out. BUt the disc has work in it before, but if I pull the fuse to the radio out and put it in again, it will work, but after awile it starts all over again. Is there anything I can do??
Old Jul 31, 2006 | 04:02 PM
ttocs's Avatar
ttocs
Default RE: Mach 500 Cd-changer problem
have you tried a laser lense cleaning disc? If not try it....
Old Aug 5, 2006 | 12:40 PM
Simon G's Avatar
Simon G
Well I just tried to clean it with a lensclenerdisc, but the problem is still there. I've noticed that the problem only appears after trying to play a disc that isn't so good (ex scratches), but if I reset the radio with th fuse I can play it as usual, but if I put in the bad disc it will spitt them all out.
Old Aug 10, 2006 | 07:06 PM
Simon G's Avatar
Simon G
BUMP BUMP!!
Old Aug 11, 2006 | 12:49 AM
ttocs's Avatar
ttocs
you are not supposed to use burned disks with sticker-style labels on them.
Old Aug 11, 2006 | 06:09 PM
Simon G's Avatar
Simon G
I haven't.... I've only used burned discs with marker pen label on them... (?) I read in the manual that you only should use that kind of discs. So thats not the problem.
Old Aug 12, 2006 | 12:50 AM
ttocs's Avatar
ttocs
Then it sounds like bad equipment. I don't think you will get your dealer to agree but.....
mtgldr
Feb 3, 2024 09:00 PM
04stangman
Sep 17, 2015 01:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
TimeLord101
Sep 4, 2015 09:27 AM
iamgobono
Sep 3, 2015 12:37 PM
