installed new cd player, need help
Old Aug 6, 2006 | 07:27 PM
str8wick3d's Avatar
str8wick3d
Default installed new cd player, need help
I installed a new sony cd player because my 6disc got totally messed up, and everything works fine until you turn it up... The speakers in the front seem to crackle and cant handle it. But with the 6 disc it seemed it was alot louder and didnt have any problems. Could this be due to bad wiring or what?
Old Aug 6, 2006 | 07:49 PM
ttocs's Avatar
ttocs
Default RE: installed new cd player, need help
sounds like you wired your deck into the factory premium system(mach?)?
Old Aug 6, 2006 | 08:33 PM
str8wick3d's Avatar
str8wick3d
mach 460
Old Aug 6, 2006 | 09:00 PM
Gargy's Avatar
Gargy
What head-unit did you put in it? Without being able to hear it, you're probably clipping the tweeters (#1 way to blow them up, but with stock Ford speakers you won't be losing much, lol) Best thing to do is keep the volume low until you get better component speakers, Ford speakers are pretty crappy.
Old Aug 6, 2006 | 09:01 PM
Gargy's Avatar
Gargy
EDIT: ANd I just committed applejohnnery. Can somebody delete the first post?
Old Aug 6, 2006 | 09:14 PM
ttocs's Avatar
ttocs
check out page 2 of my cardomain page in my sig. It shows (IMO after 10+ yrs installing) the best way to integrate into the car. I assume you left all the speakers and wires the same?
Old Aug 6, 2006 | 09:48 PM
str8wick3d's Avatar
str8wick3d
apprently, i just ear tested and nothing is coming out of the front speakers on the bottom, just the tweeters, this is a sony xplod deck and a 2004 mustang.
Old Aug 6, 2006 | 11:47 PM
ttocs's Avatar
ttocs
you need to connect the remote turn on from the deck to the amp turn on in the hrns. It will be REALLY easy to blow those front speakers (top)off of the deck power playing full range. Invest a couple of bucks into a set of capacitor/x-overs and they will last and sound descent enough until you want to replace them....
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
