dynamat
Old Aug 9, 2006 | 03:24 AM
handyandy's Avatar
handyandy
Default dynamat
What do you guys know about dyna mat? I've heard about them reducing rattle etc... what do they actually do??
Old Aug 9, 2006 | 04:43 AM
Goosepoop302's Avatar
Goosepoop302
Default RE: dynamat
it will reduce rattles caused by vibration from your soundsystem mostof the time, it also helps with road noise. ever herd the *** whos trunk rattles to **** and it sounds like bolts will fall out?? well dynamat helps eliminate that rattle sound and it help insulate your car so its quieter and better osunding inside
Old Aug 9, 2006 | 04:48 AM
Jimmz's Avatar
Jimmz
Default RE: dynamat
Dynamat is a sound deadner, it helps reduce road noise and rattle....
Old Aug 9, 2006 | 09:55 AM
Mr_Kebo's Avatar
Mr_Kebo
Default RE: dynamat
Works but is overpriced IMO. There are cheaper alternatives such as eDEAD,second skin,hushmat, Or the cheapest of the ways and the only product i use is peel and seel from lowes or home depot. its 13 dollars for 75sq ft. Some people say its gives off a funny smell when it gets hot but i have used it in about 13 vehicles and not one has smelt yet, and it gets pretty hot down here.
Old Aug 9, 2006 | 11:02 AM
ttocs's Avatar
ttocs
Default RE: dynamat
Yup, whut he said above...
I have used a few different brands with varying results. Check out brown bread as well. I applied it 3 yrs ago in my truck and it has lasted through the phoenix summers. Make sure to clean the area before applying. Go over it with a damp rag, and then some alcohol.......
69FB
Aug 18, 2015 08:50 PM
nicarc369
Jul 19, 2011 04:52 PM
06stangGT
Aug 6, 2007 01:09 PM
richmod
May 3, 2007 12:01 AM
Azure
15
Jan 24, 2007 12:46 AM
