Old Nov 4, 2015, 11:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
radar detector install ?
Old Jun 15, 2004 | 06:32 PM
mdgosch's Avatar
mdgosch
Default RE: radar detector install ?
Is it easy to get access to the back of the dash or do I have to strip off a bunch of access panels.
Old Jun 15, 2004 | 06:34 PM
Krusher's Avatar
Krusher
ORIGINAL: mdgosch
well you don't need to take apart the dash... just pull the a pillar off and pull the door sill off and pull the kick panel off and run the wire behind the a pillar and the kick panel and it will provide you a perfect location (hidden) to put the wires into the dash to where the fuse panel is.
Old Jun 15, 2004 | 06:39 PM
mdgosch's Avatar
mdgosch
Tks alot for your help. I like to keep a clean inside
Old Jun 15, 2004 | 07:55 PM
propellerhead's Avatar
propellerhead
Take in-progress pics of your wiring installation. I miss the auto-dimming rear view mirror in my Expedition and I would like to put one in my Mustang. I'll need power to the mirror, I'm sure.
Old Jun 15, 2004 | 08:03 PM
mdgosch's Avatar
mdgosch
I will try.....I will be doing it this weekend if everything arrives.
Old Jun 16, 2004 | 02:19 PM
tyybo's Avatar
tyybo
I had this idea to hide a radar but i dont know if its a stupid idea of a fairly good one. Ok id dissasemple a regular radar. run the sensor into the grill, maybe hide one by the rear license plate too. then run them into the glove box to a switch and i dont know what to do with the speaker though. do you think that this would work?
Old Jun 16, 2004 | 02:25 PM
mdgosch's Avatar
mdgosch
get one of these if that is what you want.
http://www.k40.com/Products/Radar/Un...ualRemote.html
Old Jul 6, 2004 | 09:54 PM
kingsnake's Avatar
kingsnake
If you are looking to hardwire a radar directly into your car and don't mind spending a little money, I would definately suggest the Beltronics ProRX75plus. It's a concealed system that mounts directly in your car and is one of the most discreet systems on the market. It has 2 front and one rear sensor that mount directly to the front and rear of the vehicle (hidden of course). It senses all laser bands and their intensity, blocks all laser bands, and is undectable by that pain in the *** Interceptor VG-2 Radar Dectector detector that cops love to use so they will never know you are using a radar. It also has an optional display that can be mounted in dash, or just mount the speaker for audible warnings and leave out the display so no one can see that you have it installed. Even with the display, if mounted in a good location when it's turned off most cops wouldn't have a clue that it's a radar.
Old Jul 16, 2004 | 03:35 AM
Rizzox58's Avatar
Rizzox58
Hey was just wondering if anyone has ever installed there radar detected above there rear view mirror and if so how does it work and do u have any pics and where did u put the wire at ? thanks!
Old Jun 9, 2010 | 10:20 AM
04AZUREBLUEMACH1's Avatar
04AZUREBLUEMACH1
Default Radar Detector
I have my cheap 6-band Cobra Radar Detector on my winshield just above the dash. I hardwired the power lead behind the radio and ran the wire up through the side of the defogger vent opening. There is about 2" of wire visible going from the detector to the vent.
My cheap little $30 detector has saved me many times. As long as the cop you're approaching guns someone else first, your detector will pick it up. If you're driving all alone and get caught by "instant-on," well, then that's just your fault.
My car is extremely loud and I have the detector in plain view, yet I always get away with warnings.
