07 GT Antenna Relocation
Old Aug 18, 2006 | 11:14 AM
gperry's Avatar
gperry
Default 07 GT Antenna Relocation
Has anyone had any experiance removing the stock fender mounted antenna and replacing it with an interior windshield mounted antenna?
Or any other options for alt antenna mounting would be a help.
I think without the antenna that area would be smoothed out!
Thanks GP
Old Aug 19, 2006 | 10:37 AM
ttocs's Avatar
ttocs
Default RE: 07 GT Antenna Relocation
you can always try a simple strip mount antenna. They are easy to install and cheap.
Old Aug 19, 2006 | 11:07 AM
RoadLizard's Avatar
RoadLizard
ORIGINAL: gperry
Thanks GP
Be careful removing the stock antenna. I was turning mine to remove it and the screw at the base of the antenna snapped of 1/2-way down in the base. Guy at the dealership said they probably have lock-tight on the threads. That base is a pain to remove as there is a support right over the access to it from the engine compartment...
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
kevsgt
Oct 9, 2015 10:12 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
