PLEASE HELP - BRAKELIGHTS
Old Sep 26, 2006 | 03:04 AM
Allstar's Avatar
Allstar
Default PLEASE HELP - BRAKELIGHTS
ok so my brake lights wont illuminate when i step on the brake but my runnign lights do turn on so the bulbs cant be dead because they light up when the running lights are turned on and off.. i checked the fuses under the drivers side dash and there all fine what can my problem be?
Old Sep 26, 2006 | 07:08 PM
ttocs's Avatar
ttocs
Default RE: PLEASE HELP - BRAKELIGHTS
check the fuses under the hood as well. If you have a voltmeter check and see if you have voltage at the lights, I had a buddy's truck burn out both break lights and I guess near the same time. If you don't have power there, and the fuses under the hood are good, then check the switch at the break, its above the pedal.
07 Showstopper
Jul 29, 2011 03:28 PM
waggs
Jul 14, 2010 06:18 AM
Vegasfilter
Feb 28, 2008 07:22 AM
02stangridin
Jul 7, 2007 11:34 PM
