Ipod Placement Ideas
....if i get lazy i just set it under the e-brae...mine is actually a cup-holder mount...it has its own little "seat"...theres not much to work with our dashes and center consoles...maybe get the clock pod (like the 94-98s where people install the saleen gauges) and have it mounted sideways...that would look kinda clean
Ashtray, or get a direct connect iPod for your deck, then you can just put it in the glovebox or middle console and not have to worry about juggling it around when your driving it or mounting it anywhere easily accessable.
ORIGINAL: redass02gt
they have these flexible-arm mount things that screw into the side of the center console or wherever you can think of.
didja check out crutchfield?
I still have that gaping void from removing the stock CD player. The Ipod fits perfectly in that spot when its on its side...I may try to fabricate something but I dont want it to look cheap.
I may put a screen over the hole, then to the direct connec thing to my deck. If I do that I will just attach the ipod to the inside of the glovebox.
Thanks for the suggestions everybody!
cut a shallow hole in the lid to your center counsel, and use a little velcro to hold it there when you open the lid, thats what i did with the remote to my head unit and the ipoc sits in the center councel with the bass booster, i have a direct connect cable tho
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
