Amp Ground Wire problem
Old Nov 18, 2006 | 08:49 PM
cglen07's Avatar
cglen07
Default Amp Ground Wire problem
i cant seem to find a good grounding location for my amp in my trunk. i have a 2000 mustang so if anyone else has figured this out please let me know. with the wire they gave me i only have about 3 feet so not too many options
Old Nov 18, 2006 | 10:48 PM
techmanBDsStang's Avatar
techmanBDsStang
Default RE: Amp Ground Wire problem
I just used a self tapping screw, and sanded around the area to get a good connection to the metal. Just make sure you check underneath in the area to make sure nothing is there.
Old Nov 18, 2006 | 10:57 PM
ttocs's Avatar
ttocs
where abouts in the trunk is your amp? make sure you check on the other side of what ever you are tapping a screw into. Grounding your amp to your gas tank will not help the sound, or milage......
Old Nov 19, 2006 | 10:56 PM
cglen07's Avatar
cglen07
thanks guys... i was tryin to find an already existing screw but i went with a self tapping one and it worked awsome
thanks a lot
jpplaw
Mar 19, 2025 08:53 AM
toastintx64
Aug 29, 2015 05:12 PM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
Pain.
Aug 7, 2015 10:48 PM
