rockford 325.1
Old Jan 9, 2007 | 01:43 AM
elmustang5.0's Avatar
elmustang5.0
Default rockford 325.1
will this be enough to push my two 12' kicker cvr?
Old Jan 9, 2007 | 02:12 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: rockford 325.1
I would have to say no, unfortunately. Especially since it is rated at 325 W at 2 OHM load. You add subs in parallel and you are looking at 1 OHM (someone help me out here, OHM loads are not my specialty) Anyway, that output (probably peak) will not drive a pair of 12" subs, sorry []
The Jazzer
Old Jan 9, 2007 | 02:15 AM
elmustang5.0
well the subs are dual 2ohm voice coils and im looking for a 2 ohm load. how can i wire it so it can sound the best?
Old Jan 9, 2007 | 11:50 AM
Jazzer The Cat
Retired Moderator
As mentioned, OHM loads are not my specialty. I wish I could help you more, but unable at this point. What I do know is that the lower the OHM load, the "hotter" the amp will run. Amps tend to have trouble running below 2 OHMs most of the time. Some amps are designed to run with such low resistance, but heat can be an issue as well as blowing fuses if it is not set up correctly. Hopefully someone else can help, seight tends to be good at this stuff, maybe my homie will chime in on this one....
Jaz
Old Jan 9, 2007 | 12:05 PM
PReal's Avatar
PReal
No that amp will not be sufficient.
With dual 2 ohm ohm coils on each sub, you should be able to do a series parrellel combination wiring that should get you to 2 ohms. You will run the voice coils in series and the subs in parrallel.
What is you budget for an amp.
Old Jan 9, 2007 | 12:25 PM
Jazzer The Cat
Retired Moderator
ORIGINAL: PReal
I knew someone would bail me out, thanks
Old Jan 10, 2007 | 06:45 PM
elmustang5.0
well the thing is that i got everything for $300 and im not sure what to do for it to sound good. what can i do?
Old Jan 10, 2007 | 07:13 PM
PReal's Avatar
PReal
In general it is a good idea to ask before you buy.
That amp will work, but will not put out near the rms power. I would recommend getting on bcae1.com to learn a little on how to wire subs to get differernt impedences.
Again, it will work, but not in an optimal manner.
Old Jan 11, 2007 | 04:33 AM
africkanV6's Avatar
africkanV6
i kno how u guys feel about the type Rs. but do u guys the the alpine 10" type R and a alpine MRP-M450 would be a good set up wired for a 2OHM load.
Old Jan 15, 2007 | 03:47 AM
aftlcc's Avatar
aftlcc
Rockford has a lot of LOW amp and wattage applications. i.e. My ranger HAD a a 351S(rockford), now has a concept 810d. and still has 2 P212s' (rockford.) and to be honest, it hit harder with the 351. Unfortunatly, I had a bad ground. Be sure to ground toBARE metal for your ground. But i would get a different amp for those subs, or different subs for that amp.
