Mach 460 Fuse locations, PLEASE HELP
Old Jan 21, 2007 | 11:22 PM
nofear2606's Avatar
nofear2606
Default Mach 460 Fuse locations, PLEASE HELP
i have a 1998 GT coupe with the mach 460 sound system, i have ZERO bass and do not know where the fuses are.
if you could help me out that would be awesome!
Old Jan 22, 2007 | 02:42 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: Mach 460 Fuse locations, PLEASE HELP
Not sure of a '98, but as I recall, there are fusesunder the dash for the amps. I pulled them out (in fact the ENTIRE system) a few weeks back. Seems to me there were two 20 amp fuses. Check your little manual, that is where I looked. The Mach 1000 has big fuses under the hood by the battery.
Jazzer
Old Jan 22, 2007 | 02:44 AM
ttocs's Avatar
ttocs
off the top of my head I wouldn't know and would need to check my manual to find out....
When I think I have a blown fuse I normally just test EVERY fuse in the box as it often takes less time the trying to find out what circuit that is on. And then often the link them into other circuits so your dome light fuse that is blown, could be causing your problem. Don't forget the fuses under the hood either.......
jwog666
Dec 27, 2021 08:09 PM
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
