mach 1000 radio
Old Oct 12, 2004 | 08:42 AM
ONE BAD GT's Avatar
ONE BAD GT
Default mach 1000 radio
Does this radio have inputs for subs. I don't want to change out the radio but i need more bass.
Old Oct 13, 2004 | 02:51 AM
mandark's Avatar
mandark
Default RE: mach 1000 radio
If you need more bass, why not tap the leads going to your sub(if you have one in the Mach 1000...I don't know because I don't have it) and run them to a more powerful amplifier?
Old Oct 13, 2004 | 09:58 AM
ONE BAD GT's Avatar
ONE BAD GT
I have some 12" subs i would like to put in my trunk and i need to hook the radio up to the amp i also have for the subs.
Old Oct 13, 2004 | 02:29 PM
mandark's Avatar
mandark
"If" your amp has speaker level inputs (accepts the connection from the speaker wires, not RCA connectors):
1 Disconnect the rear speaker wires from the speakers. Tap into them using a T-Tap (ask any stereo store for some...they're usually free)
2 Run the wires from the T-Tap to the amp
3 Run the output from the amp to the subs (make sure you're using a crossover)
Another way...
1 Disconnect Rear speakers
2 Run the wires to crossovers
3 Run Low output from crossover to amp's speaker level inputs
4 Run the Mid-high output from crossover to the factory rear speakers
Old Oct 13, 2004 | 02:31 PM
nanaki's Avatar
nanaki
Retired MF Moderator
is it too late to get the mach1000 installed once you bought your stang with the mach460? i sense a void in my sound system in the car. i really wish i bought the 1000 now.
Old Oct 13, 2004 | 07:21 PM
Krusher's Avatar
Krusher
aftermarket systems (both quality and well... quality is the biggest and most important aspect) are better than any stock system 1000 or 460 or 10000000000000000000000000.....
A voided stereo system warranty is like a voided music cd warranty... yup... you used it... yup you wanted something else... yup you replaced it... ok, now you have a warranty from the comapny that makes the system that you're using now.
Installing a much better aftermarket system will cost less and sound better than having a 1000 installed.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
kevsgt
Oct 9, 2015 10:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
