IDMAX subs?
Old Feb 8, 2007 | 07:34 PM
Maxwelhse's Avatar
Maxwelhse
Default RE: IDMAX subs?
Cam: I'd power it with my PG ZPA 0.5 1180 rms (on its birth cert), class A. You said you have one and you've heard one? Both? Neither?
Seight: Thanks!
Old Feb 8, 2007 | 09:40 PM
ttocs's Avatar
ttocs
yes, a 0.5 has can produce more power then a small import, it will push almost any sub. AWSOME AMP.........
I use to do a lot of systems with ID but that was prior to the idmax. Never been let down by their speakers, solid as that 0.5 you have, would be a good combo......
Old Feb 8, 2007 | 10:51 PM
Maxwelhse's Avatar
Maxwelhse
So no hoser calls BS later...
Maybe I should let my other little friend come out and play too?
Anyhow, after I get the real install done in the car I may snag an IDMAX and give the board a real life review.
Old Feb 9, 2007 | 11:07 AM
PReal's Avatar
PReal
That is great looking equipment!
Just buy the damn thing. ID is a solid company!!!
Old Feb 9, 2007 | 02:37 PM
Maxwelhse's Avatar
Maxwelhse
Thanks, it was hard to find both in white (The Adcom was dealer order only in white).
Yeah, prolly pony up and get one after I get the box done the way I want. Until then... 2 $50 Audiobahn 12's and my little 50w Audio Art.
Rollin rags 2 riches, beaatches...
Old Feb 9, 2007 | 02:53 PM
PReal's Avatar
PReal
That little 50 watt audio art sounds like a great little comp amp.
I saw an old audio art series ppi on craigslist the other day and wished I had a need for one. I already have 2 extra amps lying around.
Old Feb 9, 2007 | 05:01 PM
cam2904's Avatar
cam2904
Yes I have one and heard it in other installs. ID very makes good equipment. Check out there website and go to the forums. I believe its the general and you can buy directly from ID now. I am thinking about 8's if they will fit in my doors.
Old Feb 9, 2007 | 07:20 PM
Maxwelhse's Avatar
Maxwelhse
P: You've got your manufacturers confused. Audio Art is not PPI. My little 50HC has been a beast of an amp, at 600 x 1 @ 1ohm its just a touch too small for an IDMAX. I have about 8 amps lying around, but they're all old school and were hard to find. I don't wanna part with any of 'em ('cept the "Hott-Setup" religated to use in the beater truck). Those art series PPI amps are very nice though. Somewhere I have some pics of the AA. Internally it looks a lot like my ZPA.
Cam: The ID "MAX" series doesn't come in an 8"... IDQ's do and do a nice job.Do you have an ID MAX or an IDQ?
Old Feb 10, 2007 | 03:15 PM
PReal's Avatar
PReal
Sorry I got a little confused.
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
