Subwoofer Problem
Old Feb 14, 2007 | 11:37 PM
hockeynick's Avatar
hockeynick
Default RE: Subwoofer Problem
sorry about posting in the wrong section
Old Feb 15, 2007 | 04:19 PM
hockeynick's Avatar
hockeynick
Ok after further inspection, the sub is wired correctly, and the amp fuse is not blown. The only thing I noticed is that the LCD light on the amp does not come on. I am not sure if it suppose to or not but basically my sub will still not turn on.
Old Feb 15, 2007 | 05:12 PM
PReal's Avatar
PReal
I sounds to me like your remote wire, it tells the amp to turn on, is not connected.
Old Feb 15, 2007 | 10:16 PM
ttocs's Avatar
ttocs
check power connections on the amp.
Old Feb 17, 2007 | 01:04 AM
hockeynick's Avatar
hockeynick
Where will those be located. Under the back seat or somewhere up front?
Old Feb 19, 2007 | 06:10 PM
hockeynick's Avatar
hockeynick
I had a friend check my system today with a voltometer. We are getting plenty of power up front, but somewhere between the deck (didn't pull it out) and the amp/sub the power is dropping to 2 volts. Where could the resistance be?
Old Feb 19, 2007 | 06:40 PM
PReal's Avatar
PReal
Where did he check the voltage. On the power or remote wire going into the amp. The one that reads low needs to be fixed.
Old Feb 19, 2007 | 06:58 PM
hockeynick's Avatar
hockeynick
going into the amp
Old Feb 20, 2007 | 02:11 PM
hockeynick's Avatar
hockeynick
I took it back to the audio shop where I got it installed today. They went out of business..... The only other places around are circuit city and bestbuy which have messed up several of my friends systems. Or I can take it to their competitors shop but thats kinda low to do.
Old Feb 20, 2007 | 02:18 PM
PReal's Avatar
PReal
Which one going into the amp. The remote and 12v positive both go there. Buy a mulitmeter or borrow one and we can walk through the diagnositc.
