NO power
Old Feb 18, 2007 | 10:53 PM
GIGM08GT's Avatar
GIGM08GT
Default NO power
So over the weekend someone decided they were going to fix my bass problem and ended up touching the amp control wire from the head unit to the ground wire n the amp while the radio was on. Long story short, I literally watched my $350 radio go up in a puff of smoke. So I could at least listen to music I tried hooking up the stock radio and it wont come on. All the fuses are fine so Im stumped. Any suggestions???
Old Feb 18, 2007 | 10:58 PM
easter9053's Avatar
easter9053
Default RE: NO power
I'm pretty sure you blew a fuse in the fuse panel underneath the steering wheel. Did the radio blow up in a puff of smoke? Maybe a shop can look at it for you.
Old Feb 18, 2007 | 11:06 PM
GIGM08GT's Avatar
GIGM08GT
No couldnt be that, Ichecked every fuse in the car, under the hood under the dash behind the radio. Also Im trying to avoid the shop because its nasty expensive.
Old Feb 18, 2007 | 11:10 PM
hammeron's Avatar
hammeron
well you need to determine if you have +12 volts DC
on your radio power lead. if not, then start tracing backwards
Old Feb 19, 2007 | 12:01 AM
GIGM08GT's Avatar
GIGM08GT
i guess the thing that confuses me is my HU is motorized and was able to open to eject the disk but that was it. It was blank and no sound. so there is some power just wont start any radio in there.
Old Feb 19, 2007 | 12:53 AM
Maxwelhse's Avatar
Maxwelhse
The ignition switched side of the circuit/harness is screwed up somewhere then. If the constant power lead is hooked up most players will load and eject discs. I had a Sony deck that fried that portion of its circuit and took it in for repair. Sony (at the corporate level even) couldn't figure out what was wrong with it, so they bought me a brand new one. It was even out of warranty. It cost me all of $50 for the shop labor after sony got involved. So... ya never know.
Not to add insults to injury... People think I'm crazy for fusing my remote turn on lead at the deck, but it would have saved you from your dumbass friend tonight. When you put it back together, add a fuse on the remote wire close to the deck. It will cost ya all of about $3 at radio shack. Check your owner's manual to see what size fuse ya need.
Old Feb 19, 2007 | 02:11 AM
GIGM08GT's Avatar
GIGM08GT
did it work when you put the new one in? i cant even get the stock one to work. Also I think I am getting close to the end of my 4 year warrantee at Best buy.
Old Feb 19, 2007 | 02:33 AM
jst854's Avatar
jst854
The same thing happened to me, if you turn it up all the way can you hear it a little bit? Your amp turn on is probally not hooked up, if you have the mach 460 or 1000. There is another connector that you can hook up the the cd player, because you have a slot for the radio and one for the cd player at least in my 96 gt. If i do not plug in the cd player the radio will not even play, try plugging the cd player plug into the radio.
Old Feb 19, 2007 | 02:37 AM
GIGM08GT's Avatar
GIGM08GT
ya I have the Mach 460 and I was using a radio out of my buddies 95 Gt and it didnt have the 2 unit set up like mine so I dont know if there is a compatibilty issue there or what. I would think it would at least light up though
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
