Help wiring my sub
Old Mar 3, 2007 | 02:13 AM
JayBanion's Avatar
JayBanion
Default Help wiring my sub
Ok my buddy just gave me a 800w pioneer 12'. Tonight I bought a 800w american pro amp and the whole wiring kit. What color are the wires coming from the stock mach 460 head unit for the sub? Cuz im guessing i need to splice into these.
Old Mar 3, 2007 | 02:21 AM
easter9053's Avatar
easter9053
Default RE: Help wiring my sub
You shouldn't have to splice into but one wire. The headunit accesory wire, or power antenna wire, to run the remote wire from the amp to the headunit. Ground wire to chassis in the trunk and power wire from amp through the firewall to the battery and of course with the inline fuse.
Old Mar 3, 2007 | 01:22 PM
PReal's Avatar
PReal
Here is some guidance
Since you have a stock HU you will need a Line output converter (available at any car audio store) and will need to splice into the rear speaker wires. It is easier to go ahead and splice at the rear of the car instead of running your rca all the way back.Also, If the mach 460 has an stock amp, there will be a remote turn on wire to that amp, tap into it to get your 12V switched outlet.
BTW easter, It is generally a poor idea ot tap into the power antenna wire becuase then your amp only works when the antenna is activated. On many cars, the power antenna is only activated when the radio is on, not when a the CD or tape player are activated. This is not the case on all cars, but it is a good idea to steer away.
Old Mar 4, 2007 | 01:38 AM
JayBanion's Avatar
JayBanion
so what color is the amp turn on wire for the stock amps?
Old Mar 4, 2007 | 02:14 AM
luckydawg003's Avatar
luckydawg003
Those amps really suck. I tried some years back, and ended up blowing like 3 of em. their total crap. Good luck with yours.
Old Mar 4, 2007 | 02:15 AM
PReal's Avatar
PReal
I am not sure. I don't have a wiring diagram for that car.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
