Mach 460 detailed break-downs & descriptions?
Old Mar 3, 2007 | 07:57 PM
markmeinteil's Avatar
markmeinteil
Default Mach 460 detailed break-downs & descriptions?
I'm sure I am beating a dead horse here, but does anyone know of a webpage, or other source that has break-downs and illustrations with descriptions of the mach 460 system? I haven't had my '00 mustang long enough to dig into it yet, plus it's too s*tty outside to mess around with it. But, I would be really interested in finding detailed info on this audio system.
For instance, does the head unit power any of the speakers on it's own power? If not, how many factory amplifiers come with it? Where's the factory sub located? Wiring break-downs. etc.
Since the previous owner of this car (my sister) had an aftermarket deck, amp and subs before taking them out, I'm stuck with the original mach system which still sounds good, but I know the factory amp/sub isn't working on it. So, once it warms up a little I want to find out what's going on with it.
Old Mar 4, 2007 | 02:30 AM
jst854's Avatar
jst854
Default RE: Mach 460 detailed break-downs & descriptions?
I assume you have the mach 460 not the mach 1000. The mach 460 has 3 amps and 4 subs. Two in the doors and two in back. There is one amp underneath your radio and the other two are in back under the speakers, you can see them from the trunk. I think that the radio has some power going to the amps as a high input level.
Old Mar 4, 2007 | 02:57 AM
markmeinteil
Well that does answer some questions right there. Thanks
Old Mar 4, 2007 | 07:42 PM
Smooth_J's Avatar
Smooth_J
If you want to look inside the 6cd changer... go here:
https://mustangforums.com/m_1239231/tm.htm
If you want nice specs/how to replace your HU, go here:
http://www.stangnet.com/Tech-Article...Head-Unit.html
Old Mar 4, 2007 | 08:00 PM
ttocs's Avatar
ttocs
page 2 of my sig.......
Old Mar 4, 2007 | 08:59 PM
markmeinteil
ORIGINAL: Smooth_J
That's a good article there. I love seeing schematics! Wonder just how much different the 2001 model is from the 2000 (as far as wiring is concerned)
Old Mar 5, 2007 | 07:24 PM
Quicktime_GT's Avatar
Quicktime_GT
Mach 460:
http://www.evisteon.com/prod_serv/mo...60/index.shtml
6 cd changer:
http://www.evisteon.com/prod_serv/mo...io/index.shtml
here is some good info.. not sure how accurate it is though...
http://www.flemworld.com/Mach460/Mach.html
here is some more good stuff... This says the speakers being wired in parrallel actually drops the ohms to 3 ohms...
http://forums.stangnet.com/archive/i.../t-538244.html
Old Mar 6, 2007 | 03:29 AM
MustangMike2001's Avatar
MustangMike2001
The harnesses look alike but the wiring is different between the pre '01 and '01+ 460 systems. On the pre '01 the larger rectangular harness justusesall the power and ground connections and all of the signal wires go to the smaller amp harness. On '01+ the large harnessuses all powerconnectionsAND signal wires. The smaller harness has two low level inputs (L & R), two power turn on's and two grounds for the amps. Best thing to do is buy the proper harness kit and plug it and forget it.
Old Mar 6, 2007 | 04:20 AM
markmeinteil
Thanks for all the input. I'm beginning to understand how the 460 system works now. I've gotta say for a factory system, ford did a pretty good job on it.
Old Mar 18, 2007 | 01:07 AM
markmeinteil
I finally got around to installing my aftermarket deck today. The install wasn't too bad aside from spending a half-hour soldering all the wires to the line converter.
Bokeo
Oct 10, 2015 08:28 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
