building a box
Old Mar 8, 2007 | 07:04 PM
eddiev22's Avatar
eddiev22
Default building a box
ok i want to build a box with 2 12' subs or 1 12' sub firing into the cabin (which should i do?)
my friend told me i needed MDF wood and then screws/glue gun/carpet
for the box, i was searching, where the heck can i get MDF wood? lol
Old Mar 8, 2007 | 07:10 PM
PReal's Avatar
PReal
Default RE: building a box
MDF is not wood. It is medium density fiberboard. It is made by compressing saw dust at high pressures and temperatures and using glue to bind the particles. It is available at just about any hardware store and it around $20 for a 4'x8' sheet.
You will need 1.25 inch coarse thread screws (orange label and home depot and lowes) Make sure you pre-drill the holes and possible countersink.
For added adhesion use some sort of liquid nails to hold before you screw. (I prefer the one with silicone)
After everthing is together, get a tube of silicone caulk and run a seam over all the joints. Let it cure for at least 24 hours (becuase the silicone fumes eat sub surrounds) and then you should be ready to go.
You can buy a terminal cup at radio shack or possible home depot. Make sure you seal it with silicone also.
For carpet I use 3M headliner adhesive, a razor blade, and buy my carpet at autozone or wal-mart.
There is also a great writeup on www.bcae1.com
Old Mar 8, 2007 | 08:06 PM
seight311's Avatar
seight311
Go slighty more in depth and mabe how to do calcualtions etc and you should throw that in the information thread!
Old Mar 8, 2007 | 10:43 PM
PReal's Avatar
PReal
The calculations depend on the woofer. I usually follow manufacter specs on box type.
That website has some great calculators.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
