Will a 12" fit??
Old Mar 12, 2007 | 02:46 AM
PReal's Avatar
PReal
Default RE: Will a 12" fit??
What do you have picked out right now? Have you bought anything yet? The equipment helps determine sq.
Old Mar 12, 2007 | 03:55 PM
Lando10's Avatar
Lando10
Power Acoustik **** 12" - 2400 Watt max, 1200 Watts RMS.... powered by Power Acoustik A1800 DB Monoblock amp
Old Mar 12, 2007 | 05:00 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Wow.
I haven't heard of ****'s in a longggggggg time.
Old Mar 13, 2007 | 01:55 AM
PReal's Avatar
PReal
Have you already bought that stuff. The **** is loud as crap but sounds like poo. You can get similar spl out of a much better sq driver.
Old Mar 13, 2007 | 03:48 PM
Lando10's Avatar
Lando10
havent bought anything yet.... was wondering about the sound quality though cause i cant really listen to sound clips of it due to it being a sub. I dont really want something that sounds like Type Rs cause they are more of a punch bass and i want quality bass.... any sugestions for something else... im gonna need something that has an RMS similar to that cause i only want to by one sub.
Old Mar 13, 2007 | 04:01 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Shoving big speakers into a tiny space does not = good sound.
IMO and based on my own experience, scrap the 2 12" idea or even the single 12 and go with a 10" or two 8". A properly built enclosure with enough volume is far better sounding and can reach higher decibles that shoving big or many speakers into a tiny space. There's different enclosure types (1st order, 2nd order, 3rd, order, etc bandpass) as well as different speaker characteristics. Some are designed specifically to be used in a ported enclosure, while others work best in a sealed enclosure, and even others work in an infinite baffle setup (no enclosure).
First figure out what type of music you listen to - type of enclosure used will impact sound characteristics (Boomy or tight)
Secondfigure out what type of box youneed/want and the amount of volume you have to work with.
Third, go buy the speaker(s)
fourth, build the enclosure
http://www.caraudiohelp.com/custom_c...udio_boxes.htm
http://www.bcae1.com/spboxnew2.htm
Old Mar 13, 2007 | 04:45 PM
06z28eater's Avatar
06z28eater
yeah i bought a kicker comp vr 12 and a kicker amp didnt even think that it wouldnt fit, could not find a box for nothing to fit! i found 1 box that i got to fit sideways, against the rear sidewall, it looks ok i guess, i may take the spare tire out and mount the sub in that spot or trade it for some 10's i dunno yet i need to build my own box also
Old Mar 13, 2007 | 05:25 PM
PReal's Avatar
PReal
ORIGINAL: Derf00
In general correct.
One key aspect to remember is that if you design the box smaller then recommended specs, you will generally get better SQ with a small sacrifice in SPL. Also when in a smaller enclosure, you must provide more power to get the same amount of volume.
So, if you want SQ, buy a 12 and put in a small sealed box with morepower to drive it.
Old Mar 13, 2007 | 09:52 PM
Lando10's Avatar
Lando10
sooo what would u recomend for nice sounding base that is still pretty loud?
Old Mar 14, 2007 | 05:09 AM
PReal's Avatar
PReal
Do you have an aftermarket HU? If so, how many preouts?
