tweeters
Old Mar 26, 2007 | 12:36 AM
jst854's Avatar
jst854
Default tweeters
Well, i have the mach 460 and my right front tweeter blew, Should i just replace it with the stock speaker, or would it be worth it to go aftermarket, if that is possible using the stock amps?
Old Mar 26, 2007 | 12:48 AM
seight311's Avatar
seight311
Default RE: tweeters
Absolutly. I would definatly lookfor a new component set for your front stage. Something basic would definatly work, and you'll be one step ahead when/if you decide to add an amplifier, subwoofer(s) etc.
Old Mar 26, 2007 | 02:30 PM
jst854's Avatar
jst854
Well, I actually do have a 2 subs right now and an aftermarket head unit. So will a different set of tweeters work with the factory amps?
Old Mar 27, 2007 | 12:01 AM
seight311's Avatar
seight311
Factory Mach amps I believe operate at 8 ohm. If you want mosey through a junkyard and just snag one until you get around to installing more, or what all you do have so far.
breaking
Oct 2, 2015 01:27 PM
TimeLord101
Sep 4, 2015 09:27 AM
ericdiver
Jun 15, 2006 01:56 AM
Frank99ta
Apr 19, 2006 11:31 PM
buening
Nov 8, 2005 06:04 PM
